STR conversions for sale currently
STR
Knifemaker/Moderator
Moderator
I'm going to go ahead and relist the Mini Manix I redid in grooved aluminum slab handles for $200 shipped.
You can see it and read about it here. Post 4 in the link below here shows it currently except I bead blasted the clip after that shot of the clip side. No movement in this lock up at all folks. Its rock solid, and smooth as silk opening and very attractive.
http://www.bladeforums.com/forums/showthread.php?t=489908
As I often try to do whenever possible this knife can be put back together just the way it came from the factory should one decide to do so.
Not real interested in trades currently and pay pal is preferred but money orders are fine also. Let me know if you are interested in it.
Thanks
STR
I don't think so at this time. I really haven't been using it much and once I get my Cold Steel Ultimate Hunter knocked out much the same way I really don't think I'll be carrying the Mini Manix much at all because I just like that Ultimate Hunter blade shape a lot and the overall function of the knife fits me better because its not as wide in the pocket.
If someone already owned the 80mm Manix and wanted this type scale done it would run them $135 for the job so if I did sell just the scales that is where it would need to be but for the whole knife obviously its a better deal here. I appreciate the offer but I suspect it will eventually sell. If not I'll just keep it.
Here is an idea. Just buy the whole thing and sell a mini Manix. :D
STR
I understand, I meant is there any chance you would be making other custom scales?
If you want a set for your Manix or 80mm Manix just say the word and I can make you up a set yes. I normally like to have the knife you want them installed on due to slight differences in each one which although slight can be enough to allow an overhang or some other such thing with production knives.
STR
This one is no longer here. Thanks
STR
