CelloDan
Basic Member
- Dec 2, 2017
Hi folks
A couple days ago I received a budget model guided sharpener system and I have sharpened two of my lambsfoot knives with very good results.
After sharpening the first one I noticed that the middle of the knife's edge had a very slight curve inwards, as in more steel had been removed in that area.
I then recalled that the grind was very uneven to begin with from the factory, so in my head problem solved.
For the second knife I made the edge perfectly straight, from tang to tip with a file before sharpening and went at it ( checked by resting edge on a piece of wood and shining a light from behind)
As the initial major re profiling was under way I noticed the the middle was the first spot to develop a burr, so I decided to concentrate more on the area close to the tang and the tip which were noticeable thicker.
I then checked the angles of the system.
Hone straight at the middle of the knife was what I had set it - 17 degrees.
On either side the angle was 16 degrees.
So I carefully raised the angle by one degree and continued to do only the ends of the blade trying to get an even bevel.
I also realized that with my system I could move the clamp/knife left to right to align either end of the knife straight in the middle of the system and just keep the original angle ( system not intended to be used this way I am sure )
The results were very good
, but not perfection . I still managed to take a very tiny bit more steel from the middle than from either side.
A lot of the vintage lambsfoot knives that have been sharpened on stones look like this.
Why ?
Any tips to be able to maintain a perfect straight edge on on these knives either with guided systems (or stones )?
Why ?
