Thanks for the good questions and interest in my subject!
I looked at the profiles of the blades and cant be sure that these are the 1/1 full hollow ground. I dont think I see that ridge running parallel to the edge so I included a link to a photo of an example of what has been industry standard for many generations. Maybe you can tell - tho not a great photo.
http://www.mmimports.com/catalog.cfm?Action=ShowProduct&ProductID=191
I see that I do have other knives that sound like the wedge you describe.
Re: The scraping process and other details.
The material, cane, is actually a form of grass. It has at thin, outer layer of bark and several under layers that get softer and pithier the deeper you cut. The initial total thickness ranges from .45mm- .6mm (with a double radius gouge) and .5mm-.01mm when finished. The deeper you cut the more difficult it is to scrape without ripping or nicking the cane. Cane varies in texture and hardness from batch to batch.
Depth per cut: This is difficult to quantify. I would say that after the bark is off, 5-6 strokes would remove about .1-.2mm of cane depending on the pressure of the knife and the segment of the knife used. In general we try to use the weight of the knife to remove material. In the finishing steps, in the pith (the tip of the reed), I will remove shavings that are smaller than dust. We want the cane to come off in smooth curls rather than small clumps.
Planing angle: The motion used is the rotation of the wrist back to front, so that the length of the scrape can be almost as long as the arc created by that movement, or only a very tight wiggle of the wrist. We must lift the blade slightly between scrapes. A backwards scrape would tear the reed.
The neutral position of the blade w.r.t. the cane is about 90 degrees. The various motions and cuts are described as scooping, planing (there is always a tiny back stroke to get the knife going), severing, blending and dusting. We scrape straight ahead, and at angles. Sometimes we deliberately put nicks in the cane, but usually this is not desirable.
The knife needs to be very sensitive and feel the unevenness in the scrape. The reed has several areas and goes from bark to thin to thicker to very, ultra thin at the tip. These areas are discreet yet united. We set up a series of vibrations that we can inhibit or enhance and the tip is so thin to control the start of notes and the luster of the sound.
The
surface of the reed is curved, from a segment of cane 10.5mm in diameter. The reed has two blades that lie back to back with an empty chamber between them. The air passes through this chamber and into the instrument via a metal staple.
The
general dimensions of the cane section is 25mm x7mm x 1.5mm ( the opening)
**To scrape on each blade individually one must use an insert a
metal plaque between the blades to support the blade that is being scraped. The knifes edge comes into contact with this metal on almost every scrape. If you watch a pro make reeds, he will touch up his edge about every other scrape.
I hope that this isnt too much information and look forward to your response.
Annr
Ps We have a saying that it takes only a few minutes to make a good reed, and a few minutes and a second to make a bad one! Actually it takes more than a few minutes and you
may get a good one -or not.
Thanks for the shaving links as well.
