- Dec 27, 2004
Ah, the fabled Sebenza. It's become something akin to a fetish object amongst knife knuts. Die-hard Sebenzanistas claim it's the most perfect folding knife ever designed.
I'm in the market for a heavy-duty folder, so when I saw the passaround, I was all over it like a pitbull on a potroast.
Having never even seen a real, live Sebenza, I tried to approach this passaround with an open mind, but I couldn't help a little skepticism; can any knife really be THAT good?
We shall see...
First Impressions
The Sebenza arrived in the mail packed in a padded, zippered case, along with the original shipping baggie, spare frame screw, small hex wrench, and a knit "booty" to keep it warm on those chilly winter nights. The original factory black cord lanyard was still attached.
(Yes, a hex wrench. Chris Reeve is one of the few manufacturers who not only makes it easy to disassemble their knives, but actually encourages doing so for cleaning. Also the only one I know of that ships their knives complete with a functional cord lanyard. But I digress.)
I've read a lot about the Sebenza, on this site, other knife sites and Equipped.org, but a few things surprised me. I noticed some nice details that were never mentioned on those sites, and never showed up in the photos I'd seen:
The spine of the blade is fully radiused. The thumb ramp is grooved for traction, but also has a slight, even bevel on the sides for comfort. Makes for a huge improvement in comfort.
The titanium frame slabs are nicely radiused all around; smaller radius on the top, to leave a flatter surface for bearing down, and a larger radius on the bottom edges, for extra finger comfort. Also, the top edges are grooved longitudinally for a better grip.
All in all, nothing flashy, nothing there for the sake of appearance alone; a practical yet refined knife.
Let's dig deeper, shall we?
A Closer Look
The most impressive thing about the Sebenza is the precision with which it's constructed. The frame radiuses and grooving are absolutely flawless, as are the blade grinds. The pocket clip is inletted into the frame; also perfectly executed.
The capper, though, is the blade pivot. For those unfamiliar with it, it's a slick piece of manufacturing technology; no matter the tension on the pivot screw, the blade opens smooth as ice. The secret is a seemingly simple bushing. The pivot hole in the blade tang is oversized, and the bushing fits into it snugly; the pivot screw in turn fits through the hole in the bushing. The bushing maintains the spacing between the frame slabs, which in turn maintains a constant friction between the phosphor-bronze washers on the blade tang, regardless of the pivot screw tension.
Sounds simple, but to do it right requires manufacturing tolerances on the order of tenths of thousandths of an inch. That sort of precision is unheard of in mass-production manufacturing.
Needless to say, the blade is perfectly centered in the frame, and the frame-lock is nicely fitted. I was a bit surprised, though, that the tang was merely angle ground, rather than concave ground; concave is more accommodating of lock wear.
OK, so, enough gushing over Chris Reeve's manufacturing prowess, and get up close and personal with the Sebenza...
While it looks a bit blocky, compared to some more "ergonomically" styled knives, it's actually pretty comfortable in the hand. Credit those nicely-done radiuses. Not sleek and sexy like, say, a Spyderco Native III or Benchmade Ares or even my beloved CRKT Ryan Number Seven, but it gets the job done with surprising comfort. This is the large model, and fills the hand nicely.
Weight is, well, just about right. Despite the all-metal construction, it's lighter than I expected, but definitely feels solid in the hand. Credit the hollow-ground blade and titanium handles for the light weight. Balance is good, right around the forefinger.
The blade sure ain't sexy, and it's not as beefy as I was expecting, but it's effective. Very wide chord, with a high hollow saber grind; I'd prefer a full flat grind, but the hollow grind makes it a damn fine cutter.
The spring tension on the frame lock is very firm; it snaps into place on opening with authority. After white-knuckle hard use, it can take a little force to unlock, but there was never any doubt that the lock was secure.
continued...
We shall see...
First Impressions
A Closer Look
continued...
