Hey guys, like many others, I am fighting warps with AEB-L. I don't mean heat treat issues, just the standard warps the bars have, plus bends occurring from profiling, drilling etc. No bevels are ground yet on any blades. What I am thinking of doing is straightening everything as good as I can, clamping between two steel plates, and doing a sub critical anneal I believe it's called. My reading says that a few hours at around 1350 should help de-stress the steel and remove some of the memory from when it was rolled. After that, I would partially grind my bevels on the .125 stock, and go straight to heat treat for the .093 and .070 stock, which would get bevels ground after heat treat.
Questions are:
Will this process help to correct any curvature I have right now, and help decrease warp during HT?
Do my temps and times for this stress relieve seem correct to you?
For a sub critical at 1300-1350, should I be foil wrapping? I have read it's low enough temp it won't hurt and I have heard that wrapping at that temp is still very important.
Lastly, if I do have to wrap, is the 1350 temp low enough that the foil packs would still be usable for the actual HT, or would I need to wrap them again. I never use packets twice at high temp, but am not sure if this would be ok or not.
Thanks in advance for anything you can assist with.
Questions are:
