Well, I've never heard of this happening before.
I was chopping away when the head flew completely off my Plumb boys ax, clean as can be. It surprised me (a lot) because the head wasn't loose, and I'd hung that ax more than two years ago and used it often since. More surprising was that both the wooden and steel wedge were still in the head. They hadn't moved a bit.
My take on the situation is this: The wedge was too wide in the eye...it had strong contact with both the front and back of the eye, which is why it stayed in the head when the head left the handle. I think it was also the limiting factor in how deep I could pound the wedge, so the sides of the handle weren't getting enough force.
Finally, it was cold...about fifteen degrees. I've been in the habit of soaking my handles and wedges in BLO before hanging them, and I think that's got some drawbacks. In the cold the BLO turns to a hard varnish which reduces friction. The steel wedge was essentially glued to the wooded wedge by the crystalized BLO. In addition to trimming the wedge I ended up scraping the varnish off both the handle and the wedge before reassembling the ax and it worked fine.
Should have taken a picture but it was cold and I was a lot more concerned with getting my ax operational than snapping pics. Here's the ax, anyway. And ya, I know the edge is ground too convex. It was a flea market find and profiled even worse when I bought it.
