This is a little review I did on this light back at the first of december, but can't remember if I posted it here at BF, this is over at KF. Anyway, I'm been really, really pleased with this light. I carry it with me all the time and it just clips in my pocket like a pen, but is constructed of aluminum and is very tough as I've dropped it several times with no problems. This is not like the cheap pen lights you can buy at discount stores, unless they are selling these.
I just picked up one of the Pro Styluses yesterday. I would have gotten the Microstream also but the store was out. This seems to be an improvment over the original Stylus, although the original's are still manufactured. The Pro Stylus is of greater diameter than the original stylus light's, but nothing that is uncomfortable to wear in the shirt pocket.
These lights run on AAA batteries, the Pro has 2 AAA's, is 5.25" in length, and produces 24 lumens, while the Microstream has 1 AAA, is 3.5" in length, and produces 20 lumens. These lights also have a reflector and a lens so that the LED is enclosed within the body of the light, unlike the original whose LED sticks out the front and is unprotected. The beam has a good center focus and has more than enough overspill to make walking in the dark no problem. I would not feel under equipped if this was the only light I had when the lights go out!
Her's some specs on both;
PRO STYLUS
HIGH-POWERED LED PENLIGHT. Streamlights new high flux LED light with Proprietary Micro Optical Systems has Battery-Booster electronics to provide a super-bright beam.
Proprietary Micro Optical System (MOS), for optimized output and runtime
Up to 24 lumens output for up to 7.5 hrs runtime
Super-bright 1/2 watt, 30,000 hour high flux LED
An internal polymer body liner and shock proof switch housing allow for operation under the most extreme conditions
Rubber push button tail cap switch
O-ring sealed
Unbreakable polycarbonate lens
Unbreakable pocket clip
Belt Holster included
Corrosion and water resistant construction
Water resistant per IPX4; in accordance with specification EN 60529:1992
Shock-proof; drop test verified above the industry standard of six feet
Type II MIL-SPEC abrasion and corrosion-resistant anodized aircraft aluminum
Includes (2) AAA alkaline batteries and holster
1.64 oz. with battery
5.3 long
Available in Matte Black
Limited Lifetime Warranty
PRO STYLUS
O-ring sealed
5.3 long
