I just picked up one of these yesterday. This is the 2nd generation of the stylus light by Streamlight, and seems to be a vast improvement over the original. It uses two 3AAA batteries and puts out 24 lumens according to Streamlight. There is also a single 3AAA battery model, but not sure of the output. The one I have is about 5.25" long and is about 9/16" in diameter at the top and the bottom with the bulk of the body being 1/2" in diameter. It does have a greater diameter than the original but is still very easy to clip and carry in a shirt pocket. The LED is enclosed with a reflector and a polycarbonate lens. The original had a LED that just stuck out the end of the body. The on/off switch on the Stylus Pro is a two stage light with a momentary push and a click on and off. The finish is a flat black with the clip mounted very near the top. The on/off switch resembles a pen switch and does not look out of place at all when clipped into the shirt pocket. The body is aluminum and it is light enough that it does not drag your shirt pocket down making it look like you've got a brick in there! The light gives a distinct circle and has enough overspill to see well at night inside or out. I wouldn't feel under equipped if this was all the light I had when the lights go out. Well worth the $27.00 I paid for it, got it at a brick & mortar store. I expect it to be less expensive online.:thumbup::thumbup::thumbup:
STYLUS PRO™HIGH-POWERED LED PENLIGHT. Streamlight’s new high flux LED light with Proprietary Micro Optical Systems has “Battery-Booster” electronics to provide a super-bright beam.
Proprietary Micro Optical System (MOS), for optimized output and runtime
Up to 24 lumens output for up to 7.5 hrs runtime
Super-bright 1/2 watt, 30,000 hour high flux LED
An internal polymer body liner and shock proof switch housing allow for operation under the most extreme conditions
Rubber push button tail cap switch
O-ring sealed
Unbreakable polycarbonate lens
Unbreakable pocket clip
Belt Holster included
Corrosion and water resistant construction
Water resistant per IPX4; in accordance with specification EN 60529:1992
Shock-proof; drop test verified above the industry standard of six feet
Type II MIL-SPEC abrasion and corrosion-resistant anodized aircraft aluminum
Includes (2) “AAA” alkaline batteries and holster
1.64 oz. with battery
5.3” long
Available in Matte Black
Limited Lifetime Warranty
Here's the info on the single AAA battery model, called the Microstream
Up to 20 lumens output for up to 1.5 hrs runtime
O-ring sealed
Key ring and safety lanyard included
Includes (1) “AAA” alkaline battery
1.04 oz with battery
3.5” Long
ACCESSORIES
DOCS/INFO
O-ring sealed
5.3” long
O-ring sealed
3.5” Long
ACCESSORIES
DOCS/INFO
