I really love Boye Dendritic 440C. The stuff is stain resistant, has toughness properties roughly equivalent to ATS-34, and holds an edge very well. To my way of thinking, it is kind of an exotic equivalent of CPM440V in terms of performance. I am sure heat treatment is a big variable, but my Barry Dawson 440C blade goes dull at a steady rate. It is very predictable, make a hundred cuts through cardboard, and the edge will show obvious need of touch up. With BDS, you get tired before the edge goes away, similar to the performance of tool steel edges. Boye claims BDS is more wear resistant than tool steel, but I would say they are closer to even. I think of it as stainless tool steel.
You could conclude from the comparisons to ATS-34 and 440V that it is not excedingly tough, and you would be right. David hollow grinds the edges on his folders nice and thin, and they chip under moderate lateral force. However, on his flat ground customs and basics there is more metal behind the edge, and they are quite strong. The thin edges cut like stink! You really have to try a knife with an edge like this. This kind of cutting performance is what keeps people buying $800 chisel ground Phil Hartsfield blades. They just don't realize it isn't magic. Everyone should know the price they are paying in cutting efficiency for those thick strong edges on those "combat" knives.
In the test that Gary alluded to, David cut about half way around an oil drum with one of his 7" kitchen knives without significant damage. That knife is at the David Boye Gallery, and the edge is just a tad thicker than on his usual kitchen knives, but there is very little chipping in the edge from the oil drum ordeal. It held up very well. BDS is great stuff, probably not as tough as A-2 or L-6, but tough enough for utility hunters and kitchen knives, and very stain resistant too. When I asked David about the toughness of BDS, he said you probably wouldn't want to make a sword out of it, but anything else...why not.
Regarding BDC (cast Stellite), Boye says that casting Stellite makes it tougher, and I think it is on a par with Talonite from what I have seen, but it is still only suitable for moderate use when the edge is thin. Talonite seems to do very well in blade formats with thick edges, and I think BDC would too. There is still the question of impact deformation though if you plan on chopping with it. Boye originally brought out BDC for a dive knife version of the Basic III, and it seems perfect for diving knives, after all, how you gonna chop something underwater? (Answer: very slowly)
[This message has been edited by Steve Harvey (edited 02-04-2000).]
