- Feb 18, 2016
So I'm working on just my 2nd knife and I've ruined 3 or 4 knife shaped pieces of steel and more pieces of walnut scales. I don't have a drill press so I have a VERY difficult time lining the holes up on the scales properly. When watching forged in fire the other day (I know I know) a contestant said with modern epoxy you don't really need a pin. I've been wondering the same thing myself. And also think corny bolts are way overkill. So let's find out!
The test subject is a .128 piece of 80crv2 that didn't make it to heat treat. Scales are 2 pieces of 3/8 unstabilized walnut. Not great figure but good for practice.
Let me preface this by saying normally (twice. The amount of knives I've got to this point) I will drill a few .250 holes in the tang and hollow grind it to give the epoxy a place to go. I also flatten/ rough up the scales with 120g sandpaper glued to a granite surface block. Then I will wipe everything down with acetone to ensure it's all clean so the glue can make a good bond.
Well I'm not doing that on this one. I literally grabbed the steel and scales out if my scrap bin and glued them with zero prep.
I'll be using gflex epoxy, and a single .187 416ss pin.
I put the epoxy on the scales and squish the blade in between
Btw I got this thing of gflex from iboats.comand it was less than 20 bucks shipped and it arrived in 24hours. Fyi.
Alright now I will let it set up for 24 hours then I will do some kind of clean up and then attempt to destroy this thing.
Plan is to try and separate the scales from the tang. If it does separate. Then I will do the test again but with properly prepared tang and scales and I will use 2 pins instead of 1.
Thanks for following!
-Justin Schmidt
-Justin Schmidt
