Sharpen it and test it on a 1/4" brass rod, if it chips it's too hard, if the edge rolls and stays bent, it's too soft, if the edge flexes and comes back true your about rite.
The only way to judge by temp is to have clean steel in the oven, no oil or residue of any kind, and even that's subjective. Get a good thermomiter from the grociery store. Depending on what kind of oven was used, a home or toaster oven for example, if you put in cold and then turned the heat on it can spike on the first heat a lot hotter than once it's up to temp. Leave the blade out till the oven's cycled a couple of times and the thermomiter leavals out.
The smiths of old tended to do one part rite, two parts wrong, and the realy good ones tested there blades and didn't let bad ones leave with there mark on it. They also did something that is hard for a part time smith to do, they worked all day every day and just by hand and eye had a lot more experiance than most of use have time to aquire. That's where a little tecnoligy comes to our aid.
Good luck and let use see a pic of the finished knife.
