AT1984
- Mar 27, 2014
I bought a new Stretch ZDP-189, and put a deep carry clip on it. I only carried it a few times. Yesterday, I noticed the blade was a little off-center, so I loosened the handle screws slightly (yes...slightly!), to see if the blade would center. The lockback hinge screw head stripped while trying to loosen it. The other screws were easy to loosen. I have a quality Torx bit, and there isn't any damage to the bit...just the screw head. I can't tighten or loosen it, now (since it never turned either way).
Also, there is blade play (open and closed) if I even *slightly* loosen the pivot screw. It's either too tight or too loose, no in-between. I can actually feel the blade scraping on the handles, when I open it. I've opened this knife countless times, trying to "break it in". I've also used a very small amount of lube on the blade pivot...helps for a few flicks, then starts getting tight feeling, again.
Has anyone else had these problems with the Stretch? I really like this knife, and don't want to let it sit in a drawer. It's my favorite...next to my Zulu
Thanks!
AT1984
Thanks!
AT1984
