Two completely different animals.
The MT is more line an expensive letter opener. You won't see many people cutting steel retaining straps with a UT6. You won't see many UT6s with blade coating wore off and allot of sharpening marks and a rounded tip. Simple because while they have top notch fit and finish they won't stand up to what a Strider will. The UT6 is a great knife for what it is. Basicaly a show piece.
The Strider GB is a monster of a folder who's Liner lock is not much thinner than the blade, which is a monster in and of itself. You could ram the tip of a GB through a 50 gallon drup and the GB would laugh at you like you ae a sissyboy. You can cut steel straps and it will just need a quick touchup if that. That being said, the damn thing weighs a ton. It's heavy and large. I got rid of mine based on that fact alone. It was just too big for me to carry daily.It is however a knife that if i could only ever have one knife that my life would depend on Mick would have my order.
The UT6 might work with a suit and tie, a GB won't. A GB will work well when your lost in the woods for a few days, A UT6 might not.
My real complaint about each one is this.
Strider GB: for all that 4 inches of blade you have 2.85 inches of cutting edge. The top of the tanto point has a steeeeeep grind for tip strength and the large finger choil at the bottom doesn't help. The AR solves these problems
UT6: far to many moving parts. If it's can move it can foul up. Go ahead and set it in the bottom of a silty stream for a few minutes and see how well it fires.
