Well with another new knife comes an additional Dilemma
Once again time for a new knife and hopefully opinions of the folks of bladeforums;
Knife will be used as a field utlity knife (general chores) that is expected to go the distance under the worst of conditions if needs be. However most of the time will be used just as a general handy blade for slicing, cutting 550 cord etc.
Knife should not be too much of a burdon; I.e. Should be of a size that it can be worn 99% of the time (outdoors not in the street) without problem or interference with belt-kit.
Knife will be supplemented by a SAK / Multi-tool and occsionally a martingdale tree-beater or Axe.
Requirements;
- Hard use, reliable blade.
- Reasonable edge; While I would like a rugged blade that can withstand a reasonable amout of punishment, it should not be so rugged as to perform inadequatley for cutting cord / slicing food.
- Light chopping; knife will usually be supplemented by a Golok machete so heavier work will mostly be taken care of.
However, I would like the knife to be able to handle limbing of small trees / saplings (branches max of 2" diameter) for times when the golok inconvenient.
Knife should also be able to withstand heavier chopping (e.g. being assisted with a log) without being compleatly destroyed (light damange acceptable) incase of loss of Golok.
So basically I'm looking for (I really hesistate to use the phrase) a Survial knife, to be sit unnoticed on my belt for frequent field use, but be able to withstand what is asked from it if it should ever be required.
Choices
So far the two Strider knives that have jumped out at me are the MT Mod-10 and MT.
Largley because they seem to have a good blade shape for varied tasks, come with a very simple but effective grip material and are of a useable size with a none to aggressive blade shape.
While I do like the MT I can't help put think the smaller overall package of the MOD 10 would be more suitable for my purposes.
What I'm asking I suppose, is do you think the extra length and weight of the Standard MT is worth its increase in size for the small about extra blade length / handle you recieve ?
Conversely is the MOD-10's decreased blade size much of a disadavantage (I have smaller hands anyway so the handle size is actually probably a benifit)?
Feel free to suggest other knives (preferably Cord-wrapped Strider though others welcome too).
I have looked at Busse combat, but I'm not keen on the edge type, nor am I keen on the finger choil of the Swamp rat knives blades.
Thanks for any help or opinions given.
Requirements;
Choices
