Strider "nut" scroll question
Hello guys!
I can't tighten or loosen any bolt of my SMF. Every "Nut" (or call it whathever) on the titanium side is scrolling with the bolt itself.
Is it normal for SMF Full Stonewashed?
Can't reproduce this with any other Strider I have at the moment.
Thanks
That's common with the pivot, but not the other screws.
Sounds like someone used loctite on it.
Not sure of a solution, my apologies. Sometimes heat will loosen up the loctite, if you try that method I suggest not doing it on the G10 side:)
Only longterm negative that comes to mind is not being able to take your SMF apart should you need to clean it thoroughly.
