RokJok
- Oct 6, 2000
Cliff Stamp and other Strider PAB owners or users,
Allow me to ask about the performance of the Strider PAB since I find its general blade/handle configuration aesthetically appealing. Is it as nice a limbing chopper to drive as it appears to me? Or does more of the weight need to be moved out toward the tip for chopping? What changes would you recommend for the blade size or geometry? While the cord wrap would no doubt be secure, how is its comfort level, particularly for those cord bends on the sides chewing into your hand?
In the picture Cliff linked to the BK&T Patrol Machete thread, the PAB appears to be hollow saber ground about half-way up the blade. If that is its geometry, I'd expect the penetration curve to be high with moderate applied energy at first, but falling off rapidly once you got to the concave part of the hollow grind. However, for limbing out small branches up to about 1", you would be all the way through the branch before you got to that thicker part of the grind. Also, if it has a thin edge, have you incurred any damage to the PAB?
However, in the picture below the primary grind looks like a flat grind rising nearly to the spine. Has the PAB blade come in different geometries over time?
IMHO for an idealized chopper it sounds about right to fabricate a combination of the PAB's blade shape at 12" long, full flat ground in 3/16" INFI (or 52100/L6/A2 differentially heat treated maybe?) with distal taper, full convex edge or the Busse asymetrical edge, and driven by a PAB-angled handle with pommel swell like the BK&T handle with Cliff's suggested gentler transition in selective ROKJOK (tm pending
)beadblast finish. And as Cliff noted about the BK&T PM handle, do not have holes in the scales whose edges can chew at the hand under high pressure gripping.
The selective beadblast would be to texture the bottom surface and about the bottom half of each handle scale, where the fingers contact the handle. But leave smooth the top part of the scales where the knuckles, particularly at the base of the thumb and trigger finger, and palm of the hand contact the handle. By leaving the top half of the scales smooth the texture wouldn't be chewing (e.g. rubbing raw spots) on the fulcrum contact points of the hand that have the least padding between the handle material and the bones of the hand. Those are the contact points where a little slipping could be advantageous.
To reiterate the initial question: How good is the PAB for limbing work? Thx in advance.
