strider sheaths
My Strider is made of cordura nylon with a kydex liner. It is a very slim design and just wide enought to cover the blade. The Kydex on mine does not hold the knife very securely so I always have to use the strap, but overall it's a great sheath, and an amazing knife.
Hi Max...
The kydex in your sheath is more likely used as a stiffener instead of standard cardboard,, a lot of sheaths use ....
ttyle Eric...
Eric E. Noeldechen
On/Scene Tactical
http://www.mnsi.net/~nbtnoel
Custom made, High Quality
Concealex Sheaths and Tool Holsters
Canada's Only Custom Concealex Shop!
The older Strider sheaths were made by Eagle, the newer ones are done by Special Operations Equipment (they share a building with Strider). The kydex inside is used as a stiffner. These sheaths were designed with input from military special ops input. Strider is also doing in-house kydex, and they have also used a couple of outside vendors for there kydex work. I have all of the different varieties, and I have had good luck with all of them. Skunkworks does a great job on them as well.
Your Strider sheath is made by Special Operations Equipment. It is constructed of Cordura with a form fit Kydex liner.
If your Kydex doesn't retain your blade well, send it back for a re-fit.
Ever Vigilant
Strider Knives
