- Apr 11, 2009
I have an SNG - I carry IWB. I hadn't opened it in a few days there is now rust spots on both sides of blades! crap! :-( What can I use to clean it off. It's probably due to the humidity and moisture in the air. Thx1
A rubber eraser should do the trick. Then lube the blade with some kind of oil, olive oil works good if you use the blade to cut food. Don't know about other users, but this has worked for me in the past doing little if any harm to the blade finish. Good luck.
Matador-
Geetings Michell kde: If the rust is limited to small dot like spots on the blade sides then it most like due to water VAPOR CONDENSING on the surface of the unprotected steel. Larger patches of rust are most frequently caused by DIRECT physical contact with liquids or other moist materials. Matador's advise about using the eraser will work just fine. I suggest you use a pencil eraser not a pen eraser as some of them contain an abrasive grit which can scratch the surrounding finish. Flitz metal polish is also good but heavy use can also change the blade finish. The Stryder is a heavy duty knife and you may not be overly concerned with a pristine finish. Many people aren't but I don't know any knife nut that will tolerate rust. Carrying the knife next to your sweaty body (no offence intended) will expose the knife to rusting conditions from BOTH condensation and direct contact with moisture. Olive oil will work. It is food safe but is slightly acidic. Mineral oil is almost PH neutral and is also food safe. The underlying concept is to provide a moisture and air barrier between the steel and any source of corrosion. There are many synthetic products available that are not food safe but are superior to simple oils for both lubrication and rust inhibition. S30v is pretty good at resisting rust. Dust and other foreign material that sits on the blade due to lack of use will sponge up atmospheric moisture and hold it against the steel. Inactivity is not good for your knife. If you are daily carrying your SNG and are seeing rust spots on the blade sides then the odds are that the cutting edge is also experiencing the same condition. Its' just harder to see it. The micro serrations of the extreme edge may in fact be more prone to rust then the smooth surface of the sides. The edge is also subjected to having whatever you are cutting ground onto its surface . This material can also attract and hold moisture. Unless its' removed through use or otherwise this will reduce the cutting efficiency of what otherwise appears to be a well maintained and lightly used knife. This is just the observations of one old dude. YMMV OldDude1
contact strider...it's their product and w/ their warranty you should be in good shape.
