Stripped - B11, DSSF, CGBJ, RMD, HRLM, RS
Took just over two hours. All stripped very easily. The B11 was a little more stubborn than the others. The CGBJ did not want to give it up totally and will need some work. No sanding yet on any except the RS.
The Rodent Solution was done a few days ago as a test run and it has some hand sanding.
Apologies for the bad pics - it was getting dark. I will take better ones sometime.
Great work! Naked steel looks better than coated.
Did you tape off the scales? I tried that once and decided it wasn't worth the trouble.
I do like the stripped look also but that CGBJ is looking nasty. It will need a lot of sanding.
I did tape all the scales with the blue painter's tape and trimmed it with the utility knife in the pic. That is what took most of the time. I could probably have done everything in under an hour if not for that part. The hardest part of the whole process was putting the tape on, trimming it and getting the tape glue off the handles afterwards. I am not sure if the tape makes a difference but I played it safe.
Nice.
I keep saying I need to strip my B11. And eventually the KZII and SARQ
The sarQ does not have near enough use for me to strip it yet.
The Last set I stripped was an Ash1CG and a SS.
