Just finished stripping a ganza jack i had gotten and figured i would take some paint off the crash rat while i was at it. the finish on these guys is obviously nothing fancy and i have already scratched them up a fair bit... Since taking the coating off they both chop/slice with much less resistance and are a million times easier to clean. this was also my first foray into stropping and the satin jack is by far the sharpest knife i have ever used.
while the crash rate was as easy to take the coating off of as all the prior threads had implied the satin jack was a huge pain. although i havn't seen them on other stripped knives mine was covered with machining holes all over the grind of the blade, in contrast to the "infi dimples" present on other portions of the knife. these were a huge pain and made it necessary to move down to 220 grit paper at one point to remove them. the pic below shows what i am referring to (i had already put in some sanding time when i took this shot):
while i didn't really care about the "looks" these holes caused the knife to rust almost instantly with any moisture... regardless, i'm really happy with the results.
ryan
ryan
