strippers
I recieved a few ideas on stripping. Has anyone used or would recomend a good polishing technique ? Should I use a 1000 grit sandpaper to remove the pits of the blade and then use a metal polish compound to finish the job ?
Thanks
JR
if you are talking about the infi dimples, it will take far more agressive sanding to remove them.
if you want to put a polished finish, start with lower grit, maybe 400, then work your way up to 2000-2500 grit. if you like, you can use a metal polish at this point, but you probably wont need it.
the dimples will be on the unbeveled portion of the blade. to remove them, you have to grind quite a bit of metal off. you might consider a sanding wheel or belt sander, then apply the fine grit paper by hand.
First you need a song with a good beat.
Then some flashing lights.
Next a long brass pole.
Oh wait, wrong strippers.
He's right on. I have done this to a few busse's. It will take quite a bit of sanding to get the dimples out. I recommend something like a sanding disk for a drill. :thumbup:
http://www.bladeforums.com/forums/showthread.php?t=441376&highlight=process
http://www.bladeforums.com/forums/showthread.php?t=442050&highlight=process
