- Feb 3, 2013
Tried to strip two of my old Smith and Wesson folders.
Here they are. As far as Im concerned, they are both stainless steel. The dissassembled one is the Power Glide, and the one on the right is a newer model (not sure the name)
These are my beater knives as I have upgraded and gotten better ones, and I just wanted to strip the blades to try out an acid etching technique as well as maybe some patina or high polishing.
I live in Canada, so Klean Strip Sprayable Paint Stripper is not available to me unless I order it. I bought this stuff called DS Super Remover Paint, Glue and Varnish and it supposedly takes off epoxy as well. Heres a link to info on the product: http://www.canadiantire.ca/AST/brow...+and+Varnish+Remover.jsp?locale=en#product_aa
I dissassembled both knives, sanded them down a bit with regular sandpaper and left the gel-like substance well-coated on the blades for 20 minutes, but upon checking and scraping the surface a bit, there was absolutely no change. No paint was being removed at all. So i left it for almost 50 minutes and then checked again, and no progress. I have given up and cleaned the blades.
Also a note to add: I was doing this outside, in the cold. Its probably -10 degrees Celsius right now outside, so 10 below freezing. Would the cold temps prevent the paint from stripping?
If anyone who has used this product, or is knowledgeable about these types of products or process, could give me a helping hand that would be very appreciated!
EDIT: Now that I look at it, Im not quite sure either of them have a layer of paint or coating on them. The blade on the right most definitely doesn't have a coating on it (silver one) but the Paint Stripper that I bought couldnt even take off the Smith and Wesson black inked logo. I used some more sand paper and roughed up the camo blade, and this time I used a considerable amount of force, and I was able to scrape off some of the design, but not all of it. Could it possibly be a factory-made patina? Heres an updated picture:
