yea it can be down you just gotta get the wrist movement down, while maintaining the angle, takes a little bit of practice but it works just fine. I might add you can also use the sharpie trick while stropping to make sure your hitting the edge. Actually i suggest you do mark the edge with sharpie to make sure you are hitting it otherwise you may just spend a whole lotta time doing nothing or you could even dull your blade, which I've also done several times while learning to strop.
