Strop or Strop Block
I recently came across a scotch lassie 144 leather strop. It has been used, but is in good shape.
My question is should I leave it as is or cut it and build a stropping block?
It will be used on small to large fixed blades and maybe a hawk when I get one.
Thank you.
If you want beveled edges, mount it on a block.
If you want convex edges, leave it as a hanging strop.
Much easier this way. You can get either type of edge with either style, but this just makes the work easier.
Stitchawl
I'd just suggest going ahead and making a strop block, but use some other leather (veg-tanned). They can be made very, very cheaply, from simple materials. A lot can be learned by using both types (block vs. hanging strop), and if you cannibalize the hanging strop now, you might wish you hadn't later.
Edited to add:
You could still use this hanging strop on the 'bench', if you like, without having to cut it up and/or gluing it to a block. Secure it to the edge of the bench, or to a block, using temporary clamps or whatever. That way, you can try the strop in both ways, hanging and hard-backed, and not worry about sacrificing anything.
Thanks for the advice. I think I will leave the hanging strop and make a separate block.
Wise move. Those old strops are nice to have and making a strop block is so easy. Try some balsa wood too...bare balsa. I've been using it since mid summer and I really like it a lot.
