can I strop sharp (.5-1micron) after use of 1k grit stone or I need high grit stone or corase strop before use the .5 micron strop compound?
What I find is you can and it will work, works best if done very sparingly.
I find I get better longevity and preservation of the toothy effect by applying a slight microbevel with a 6 or 8k waterstone, just a few passes to thin out the edge side to side but still leave a lot of variation along the edge up and down. For a good medium grit edge finish most of the time I'll just strop on plain paper wrapped around a dry stone or one of my Washboards, using a moderate amount of force to get some burnishing. This won't work so well with high carbide steel but works great for fine grained stuff.
Most often my pre-set is about 26-28°. If I'm not going to microbevel, that's right where it stays, stropped on paper.
The microbevel is only a degree or so higher, not very much at all. Instead of a hard fine line along the edge that's barely if at all visible, the microbevel/polished region leaks out into the main grind a bit, becoming bright just along the very edge. On a polishing waterstone I'll do maybe five scrub passes very,very light finishing with a few backhone passes - this keeps even the terminal angle pretty acute, but thinner across than I started while preserving a lot of the up/down variation left from the 1k (or lower).
On lower RC (and even higher RC with practice) one can get a very similar effect by using a smooth steel or glass rod, but the polishing waterstone is much more forgiving and less likely to draw out the steel or raise a burr.
