Strop(s) and compound(s) set
I have a Spyderco Sharpmaker and I'm pretty new to sharpening. I'd like to get into stropping and getting closer to a mirror edge. Are there any good strop/compound combo sets that I can get or should I just get each thing separately?
Also, before I get a strop, should I get the ultra fine stone(s) for the Sharpmaker (Should I get 1 or 2?)?
I checked it out and I sent the guy an email asking what he would recommend for a newbie like myself.
Also, I was wondering, what's the difference between a belt-type strop and a wood-backed one like what Stropman sells?
The belt style strop is well...a belt the only difference I know is in operating.
For a belt strop you attach the hook to a wall then hold on to the handle then you strop away.
The paddle strop is just a piece of wood with leather on top hold the handle and strop away
Cheers!
Not only does The Stropman sell great strops, he is a heck of a nice dude. Highly recommend.
But is one more functional than the other? Is one easier for beginners?
I don't have a lot of experience but I think a wood backed strop would be easier to start with its the same basic idea as sharpening with a stone.
I don't sharpen freehand though, so it's not really the same concept...Maybe I could put the strop up against the Sharpmaker stone (so that it's at the same angle) and just do it like I would sharpen...except backwards so I'm trailing with the edge.
If you enjoy spending a lot more money than you need to, or if you are too lazy to make one cut and spread some glue, then pre-made strops are the way to go. When you take them out of the box they are ready to use.
Should you be interested in saving a LOT of money, but able to spend 10 minutes making your own strop, either order a 12"x12" piece of tooling veg-tanned cowhide leather from any of the knife supply companies or Tandy Leather, and cut it down into four strips 3"x12", pick up some scrap 3" lumber (usually free) at your local home center, some ordinary white glue or contact cement, and glue the strips down. You'll then have four strops (so you can use three different grits of compound if desired, and leave on bare leather strop to finish on,) for less than you paid for one pre-made strop. Unless you are buying a hanging barber's strop, the ones you make yourself will be every bit as effective as the ones you can buy. There are plenty of videos on YouTube showing just how to do this, but it is so simple that a video isn't really needed. Flat wood (not insanely flat.. Use what comes from the home center as is.) Smooth side up leather. Glue it down. Trim the edges. Rub on a 'little' compound. Bob's your uncle.
If you do a little woodworking to the backing lumber, they will be just as pretty. And you'll have four strops for less than the cost of one pre-made strop.
Frankly, the angle DOES matter when stropping. And it matters a lot. Read the 'stickies' at the top of the page for some excellent instruction in strop use. It isn't difficult to strop correctly. In fact, easier than sharpening. But it's also easy to do it wrong if you don't pay attention to some of the details.
Stitchawl
This is my first post, but I've been looking over here for months on sharpening and knife tips and tricks. I have been researching the same thing all day. I finally decided on stropman Billy with all 4 compounds.
Then it hit me. I happen to live in the Adirondack area of new york state. Maybe I'll try to see if one of our local leather mills have any knowledge on this subject? I'll look into it tomorrow and get back to this post. If anyone is interested?
