I happen to find Stropping to work well for me, I can bring a slightly dull blade back to sharp sometimes using just that. I sharpen my knives on several things, depends on the mood and on how bad the edge has gotten, I sharpen a lot of knives for guys at work and they don't bring them around as often as they should!
I have a nice large Norton oil stone setup to help put the initial bevels back onto a blade, then I have all three of the Spyderco Flat stones, as well as a Double Stuff and the Profiles.
The strop I have is one of my own making, glued leather to a FLAT board and rubbed in green buffing compound, though some will tell you that you needn't bother with the compound but I find it works very well.
One of the ~Tricks~? is to make sure that when you strop, that on the return stroke BEFORE you flip the knife over, RAISE the blade OFF the strop, this will help prevent you from ROLLING the edge and possibly ruining all the work you have completed. So imagine if you will, pulling the knife away from you, stropping along the strop and when you reach the end of the strop, lift the blade up, THEN rotate the knife so the edge is facing away from you, set it back down and pull towards you, again when you reach the end RAISE the blade UP off the strop BEFORE you rotate the knife...just becareful!
G2
