I've been getting weird fragile edges on my knives, and I don't know why.
I sharpen on an EdgePro and take it to the 600 grit at around 20-21 deg per side. I'm not adventurous enough yet to take them down to the 15-18 degrees yet.
Makes a rather nice edge, but not as good as with a final strop. I strop on a leather belt with Maas/Flitz metal polish. It has worked beautifully until recently.
I have been getting very sharp, ultra-fragile edges recently -- they glide through paper on their own weight (with a slicing action), but on 2 and 4 ply cardboard, they microchip -- just like a wire edge. Originally smooth to the touch, they get these little bumps and ridges after going through about 2-3 li. feet of cardboard that are actually visible.
I know I've removed the burr and the wire edge correctly, because the blade isn't fragile when it comes off the 600 grit hone, just after stropping. I use Joe T's technique of putting in a tiny secondary bevel to clean up the burr.
Then, on the strop, I usually make 3-4 passes at moderate pressure to clean up the bevel and edge, and then 1 pass at very light pressure (knife weight or less)
I can't imagine I've changed my technique; what am I doing wrong now?
Thanks!
-jon
Thanks!
-jon
