- Jul 20, 2012
Hi,
The knife of question is a custom scandi bushcrafter I got from a maker here 2 months or so ago. Since then, I've put an asymmetrical grind where I convex one side while keeping the other relatively flat. The purpose is to beef up the edge and to make feathers on a feather stick curl out more easily. In conjunction with a TON of stropping I have created a relatively convexed edge.
The problem I have is stropping it. I look at the very edge closely under a lamp and try to strop accordingly from there--when doing that for some reason I am unable to get good results. On the other end I increase angle, probably a little over the edge angle and then strop. For some reason I am getting a "toothier" sharper edge than when I try to strop at the proper angle. The last thing I've tried is placing the edge in relation to the strop at a shallow angle, under the actual edge angle. To compensate for is shallow angle I use a lot of pressure. This produces good results, but not consistently. In one instance I was able to get the edge hair whittling across the whole bevel, but I find it difficult to repeat such results.
In summary, I am having difficulty finding that "sweet spot" where I am really hitting the apex and making it sharper. It might be worth nothing that the knife has a very subtle small recurve due to the lack of a sharpening choil. Any advice will be appreciated.
Thanks,
BN
Thanks,
BN
