My edge either gets worse or no improvement at all..What kind of bad results are you getting when using the smooth side?
Can anyone tell me why I have much different results stropping on plain leather compared to stropping on the rough side... doesn't matter what I load the strop with I don't have very good results with smooth leather for some reason
I have not but I will have to give it a try. I enjoy stropping on rough leather but smooth leather doesn't do it for meHave you considered dropping leather completely, and trying on a hard surface- washboard, coarse side of a stone wrapped in paper with compound, basswood on hard backing? Leather compresses too much for me, and I round the hell out of an edge using a leather strop for the most part. Hard surface stropping made me believe the stropping was an actual technique, not this mystical thing that only sharpening wizards could do.
You could feel your edge, and would eliminate what sounds to me like the rounding of the edge you are doing. Give it 10 passes a side and chill. See what you have. If you have proper technique that should be about all you need to refine edge.
I am curious what is the point of using the smooth (non hairy) side for stropping (thank you,Obsessed with Edges , for clarification). I use only the rough side with abrasives and have good results.
What is the benefit of using the smooth side for stropping? Would it be better using a hard flat surface for lapping instead of stropping, like D Danketch said above?
