- Oct 14, 2023
I'm looking for some input on what yall do for stropping.
I have two strops, one is balsa with .5 micron diamond spray, the other is balsa with 3 micron diamond paste.
I've had great results initially stropping k390. I sharpen with diamonds, then deburr very carefully, then strop. What I'd done was a few passes on the 3 micron then more passes on the .5 micron. This first edge was amazing, I'm confident there was no burr. I cut through thick plastic banding on crating, cut boxes, many zip ties. Treated that thing like it owed me money and the edge was still good after two weeks. No reflection off the edge and was still shaving a little bit with more force. Sliced paper great.
I decided to strop it again to keep up the edge, and stropped a good bit on the 3 micron then a good bit on the .5 micron. Matched bevel well, very light pressure. The edge was razor sharp now, mirror polished. Next day at work cut through some thick felt. Then a little later went to use it again and noticed it looked like I'd bashed it into concrete. The whole edge was reflecting light. I knew there's no way after what I'd put this thing through the last 2 weeks that the steel should look like that after a piece of felt.
The only explanation that makes any sense to me is the second time I stropped it, I went overboard and drew out a burr, which then folded the next use.
I'm just wondering what yall do? I get that stropping only improves the edge that's there and can't bring back no edge. But I'm kind of shocked to have actually made a burr by stropping. How many passes do yall do before being done? Should I just skip the 3 and only do a few passes on the .5 micron when maintaining? What measure of sharpness do yall wait to see before stropping to maintain an edge, as soon as it stops shaving?
