I need some advice from the experts to the relative beginners.
I'm trying to learn how to strop. So I went to Hobby Lobby and bought a bag of scrap leather. This is quite a bit of leather scraps for $5.99. It looks to be about 7 to 9 ounces thick. Some of it is dyed and some not. So I cut two pieces 3" x about 9" and glued them to some hardwood. Although some fo the leather is dyed, none of it is waxed or finished, as far as I can tell. I have some white stropping paste that another forum member sent me but I don;t know how to apply it or even use the strop.
- Does this sound like the right leather to use?
- How should I apply the rouge or stropping paste?
- How do you make sure the leather is covered evenly? (Or do you even worry about it)
- I understand that very light pressure (the weight of the blade) is all that's needed to strop. Is this true, or...?
- Should I strop at the same angle as the edge or slightly lower or higher?
I was able to sharpen and strop a BRKT mini-canadian to a razor sharp edge, but I can;t get it to pop hairs on my arm. At that time, I was using a piece of leather my wife gave me. It's probably about 2 or 3 ounces and it has a glossy finish on it. In this case, I heated it with a shop lamp and applied the white paste. I really can;t tell if it worked or not. I mean, the blade was not "noticeably" sharper after stropping, but at least I didn;t dull it (far as I can tell).
Any helpful advice would be welcome.
