Stropping question
joesrx
Have any of you stropped with the edge pro tapes attached to a piece of backer then followed by leather. Does it work?
thanks
I have not, but it will probably work. I have not used my edge pro in a while and i might try sticking the tapes to a piece of leather.
Bare leather is (or should be) the final step in stropping. The reason being that the natural silicates found in ALL leather (and carbon-based life forms including all plants and animals) are the smallest particle size found naturally. True, there are polishing films available that give a smaller grit, but they are not commonly sold as sharpening abrasives, rather polishing compounds, and usually quite expensive.
Horsehide and kangaroo hide have the highest level of natural silicates per square millimeter, followed by grass-fed cowhide. But don't be led down the garden path by the numbers. All it means is that if you have to take 20 strokes on cowhide to produce a result, you'll only need 19 strokes on horsehide or kangaroo. Keep in mind that this is the difference in the amount of silicates found. The natural density of the various leathers also plays a part in the results, which is why horsehide has been the 'go to' strop material for bare leather strops for hundreds of years. It's the combination of natural silicates and extreme density of cell structure that makes it perfect for 'final' stropping.
Stitchawl
On a firm backing, you will most likely form a foil/burr as edge-trailing strokes usually do.
Stropping on clean leather is not very effective at removing foil/burrs.
There is a "trick" used in straight razor honing with non-adhesive film/tape to put 1 or 2 sheets of wet paper under the film. The compressibility helps to prevent a foil-edge from forming by introducing a small amount of convexity. This is usually done edge-leading however.
