Stropping the tip
I've added a leather strop to my sharpening gear, and it's improved my edges a lot. But I have some difficulty stropping the very tip of a blade without scoring the leather.
Is this going to ruin the strop? How do I avoid scratching or cutting the leather? Is it just a matter of careful manipulation, or is there some trick?
Bear
Start by stropping with a point-trailing motion. Adjust until you can see the spine at the blade-tip 'engraving' the leather, but not cutting or tearing the leather. Yes - it's manipulation.
I use the little Spyderco DoubleStuff stone hand-held to carefully complete sharpening of the bevels at the blade-tip, checking for completion by newsprint-draw-cuts. After that, it should only take a few passes on each tip-bevel with the strop to polish the bevels.
Hope this helps!
might give you some relief if you saw my strops.....all beat to heck, cut up, sliced, pieces missing, etc.
Don't worry about the strop - worry about the stropping...;)
The point where the knife meets the strop should always be traveling perpendicular to the edge.
Take a hard look at that last sentence and read it over and over again while looking at the tip and if you will stick to it, you'll be fine.
I like that sentence. Had to think about it for a moment but once you get it, its to the point (no pun intended :cool: ). Works for the Sharpmaker aswell, only the motion is reversed (against the edge).
