Often people refer to stropping & how it helps. I agree & thought I'd mention the best way I've found. Basically I try to keep the blade as close to lying flat on the strop as possible. By putting my forefinger in the middle of the blade & putting pressure toward the edge , I am able to pull the spine of the knife along the strop,(away from the edge), & follow the contour of the edge. 5 to 10 strokes on each side usually does it.
This is the final step after honing on a sharpmaker. The ultra fine stones are used just prior to this. Besides keeping your angle consistant, the best advice when using a sharpmaker is to keep it clean. An eraser does the job as you sharpen. Edges that will cut hair without touching the skin are achieved on knives with VG-10 , CPM154 , & CPMS30V steel.
I think strop technique probably varies with the type of strop used. The one I have is here.
http://www.rockler.com/ecom7/showdetl.cfm?offerings_id=2427&objectgroup_id=441&catid=54
It is used with the green compound shown. Hope you all will share your techniques & tools. Stay sharp !
