Stupid grinder questions and ideas?...
One of my dogs died Sunday and I haven't even set up my Coote yet, haven't been in the mood. Now that I got my care package of belts and some L6 steel from L6Steel (Thanks very much Micheal!!!) and I also got my pyroceram platen liner from Steve (Super fast Shipping! Thanks Steve!), I am ready to get on the ball.
Ok, so I had some ideas. I want to make a stand of some sort to get the bottom of the 10" wheel away from anything. With out one it would mangle a hand quick I reckon. I am thinking 1/4" steel plate cut to match the base with 6"-8" piece of something (4"x4" thick walled square steel tubing?) welded to that with a larger plate on bottom to bolt to whatever.
I am wondering, would it be possible to take off the guard on the 4" Idler wheel and have it surfaced with the right rubber and use it to get deep hollow grinds on small blades? I would have to have a reversible motor to do that but I think there would be enough room. Or maybe I could mount a 6" there for that. Is there any reason why it has to stay bare aluminum?
The reason why I ask is I was thinking I could probably find a huge, broke vise with a swivel base cheap. I think I may have one, I used to. One of the jaws was broke but the base was fine. It may not be big enough if I do. Anyway, I was thinking I could rig up some kind of lockable, swivel base that I could mount the grinder and motor and all to. I could then just put the grinder at 90, loosen and swivel the whole grinder 180, reverse motor and grind. Just a thought. I don't know enough to even know if it is possible to do.
If you resurface that wheel, lemme know how it works. Because I was talking to another member here about the 4" slow down wheel for our grizzly's(we already have them, let's not get into another KMG/burr king discussion. :) and yes rob, I will be ordering a KMG sometime when I sell more knives and pay off some of the school loans). Anyways, he was asking the same thing about the 4" for a deeper/shorter hollow grind. So I was thinking along same lines, except it's the bottom drive wheel, not the top idler wheel like on yours. So if ya try it lemm eknow how it works.
I admit to taking the guard off the top wheel and using it the was it is. Works OK but not too usefull. Not big enough or small enough.:grumpy:
Lynn
If you alter the crown on the rear (idler) wheel, you will have belt tracking problems.
I dont think Rob Frink would have any trouble coming up with a vertical front platen, like the Burr King, which would give you two smaller, rubber covered wheels up front, a 51/2" and a 2", aprox, when it is installed. In fact, all you would need, is to get the 51/2" wheel that would fit the coote, and have an upper arm that a live axle 2" or so wheel would go into, and a 6" or so platen would mount between, fabricated. Simple huh?;)
