Stupid Question
dredd8
OK, here it goes.
I have a finished knife with a beadblasted finish. Is it possible to remove the beadblasting somehow and get it to a satin or even mirror finish.
I am just not sure what the steel is like underneath the blasting.
Are talking about a textured paint finish of some kind?
If it's just bead-blasted plain steel, the question of what is underneath is kind of baffling.
No texture, no paint. Bead blasted. I did not know if the blasting would make the steel "underneath" rough.
you should be ok, but it all depends on how deap the bead blasted finsih is. but i dont see a problem in removing it, bead blasted finish is just what it states its a finish just like satin is a finish so i dont think it should be to deap. what do the other makers think?
Beadblast is pretty tough to remove enough for a nice polish finish. The trick is sanding off the tops of the tiny hills so that they all become one smooth surface. It's a lot of work. A scruffy wheel can turn a beadblast finish into a satin finish fairly easily.
Just look at the bead blast as a 120 grit finish. Work it down with 150 grit until all the evidence of the bead blast is gone. It can be done on a grinder or by hand . Just a bit of elbow grease.
Chuck
dredd8 said:
OK, here it goes.
No trouble at all, Depending on the manufacturer. On some knives you will find deep grinding scratches left behind. (bead blast hides those, that's why it's used) I rubbed out a cold steel uwk knife for a friend last week and it took me about an hour and a half to get to 400 grit.
If the blade is flat ground just wrap some wet dry paper around a piece of thick plastic like 1/4" plexiglass and wet it with some soapy water and rub. If the blade is hollow ground wrap your wet dry paper around a thick piece of leather (like sole leather) Hard rubber will work too.
