- Jun 11, 2006
This is a very simple way to etch your blades. first you melt wax onto your blade and let it get hard, then your use a macanical pencel to carve your logo into the wax. you then get a power suplay that has around 5 volts dc and 1-2 amps. you then need to atatch the postive wire to the plade and the negitive wire to the etching pad. for the etching pad i used i staneless steel bolt with thick pece of paper paper towle. you then make a strong batch of salt water and soak the paper towle in it. then lay the paper towle on the logo and push the staneless bolt onto the paper towle. leve it there for around 30 sec and remove. then remove the wax and you will have a very nce deap etch so deap it will catch your finger nail
here is a quick exzample
