Substitute for Wetterlings Les Stroud Bushman Axe?
Looking for a small axe for camping and backpacking and the Wetterlings Les Stroud Bushman Axe has a lot of features that I like but doesn't seem to be in production any longer. Is there another axe that has similar characteristics and functionality?
Design features of the Stroud Bushman Axe that I like:
1. Good compromise of portability and functionality - with a 1.6 lb head and 22" length it is small enough to easily strap to a pack or even put inside a pack and total weight is only about 2.25 lb. It isn't big enough for extensive felling and chopping but the additional 6-8" of length should generate substantially more force for felling and chopping compared to a hatchet.
2. Hammer poll - don't see anywhere that it says the poll is hardened but at least there is a hammer shaped poll for light work like tent stakes and stuff. Ideally the poll would be hardened to add some confidence to actually hammer on stuff.
3. Wedge shaped head - the main reason that I would carry a small axe with or instead of a folding saw is to be able to split small logs so the wedge shape is preferable to a thin head. Ideally the axe would have a high centerline rather than a full wedge. The wedge shape is less ideal for felling/bucking but would still work for small logs or I could use a saw.
The GB SFA is a similar size but doesn't have a purpose-built poll and is fairly thin, better for limbing and light felling than splitting.
A boy's axe is a good multipurpose alternative and great for car camping but is bigger and heavier than I would like for backpacking. And I haven't seen one with a functional poll.
Buy Council's Flying Fox and swap the handle for a longer one https://www.baryonyxknife.com/cotoha.html
or maybe https://www.vaughanmfg.com/Products/RB-28-oz-Rig-Builders-Hatchet__20420.aspx#.XxCUaBJ7nIU
Thank you for the great suggestions!
Out of curiosity, does anyone make a full size axe with a hardened poll? A modern version of a Rafting Axe? I haven't been able to find one and other posts have said that there are very few old ones available.
I'm not aware than anyone is currently making a full size axe with a hardened poll, except I think Liam Hoffman makes one, but they are pricey. If you watch eBay you can find one but expect to pay at least $100.
Seven pines forge make an axe almost identical, I would assume with a hardened poll. they say for light striking as heavy striking will damage the eye which would be true for the bushman also. Being forged from 4140 chromolly or 01 tool steel (your choice) it's probably of higher quality steel anyway and at $165 almost the same price.
http://www.sevenpinesforge.com/product/hammer-poll-axe/
Id also consider a Finnish collared axe
http://www.sevenpinesforge.com/product/finnish-forest-axe/
It appears they're making quality (in the heads atleast as handle fit and finish isn't amazing) reproductions of gfb, wetterlings, hultafors etc axes.
Here's a gfb sfa "inspired" axe basically a copy for half the price.
http://www.sevenpinesforge.com/product/outside-axe/
I have a Bushman ax I would consider selling.
That Seven Pines is beautiful!! It looks like the big brother to a lathing hatchet I recently fell in love with.
Husqvarna carpenters axe might be a good alternative, I forgot all about it until just now!
I have the wetterling axe. The head came loose. Get the council tool velvicut bush craft, which I also own, it’s better imo.
So...tighten it up? :)
I bumped it down more and added some axe head glue:eek:, which wrecked the axe for me but it functions fine. If I was more skilled at hafting I’d give it a go but seeing how my antique double bit came out I’m hesitant. I’m going to need some industrial solvent to free that head to try it again. :(
A real easy way to tighten up a loose head is to make a conical wedge, bore a hole in the top of the eye to the required depth, and then drive it home. You can make them yourself, or buy them pre-made. They make a nice alternative to using an iron wedge since if you ever have to replace a broken handle you can just drill it out nice and easy, and if you need to tighten it even more just drive in another.
