- Feb 24, 2000
I know that there are a lot of ways to do heat treating, but based on my very limited testing, this is what I have found out. This W-2 was received from Aldo a few days ago. I tested 1/8" pieces.
1. No prior heat treatment, just heated with a torch to past magnetic and quenched in Parks 50. RC 65. This piece was easy to break and had large grains.
2. 1600 for 15 min. Let cool 10 min. 1450 for ten minutes, let cool ten minutes. 1425 for ten minutes, let cool. Then heated with a torch to past magnetic and quenched in Parks 50. After decarb was removed, RC 64. If I removed more decarb it likely would have been RC 65. This was harder to break than #1, and had smaller grain structure than #1.
3. 1600 for 15 min. let cool 10min. 1450 for ten min. let cool ten min. 1425 for ten minutes, let cool. Then a one hour soak at 1200. Then heated with a torch to past magnetic and quenched in Parks 50. After decarb was removed, RC 65. This piece was really hard to break. The grain structure was very fine and better than #1 or #2.
Thanks to several on this forum who suggested I get All the decarb off in order to get a accurate RC reading.
In the future I plan to repeat this but use my Paragon instead of my torch, for the final heat before quenching.
I invite others to run these tests, or others and post your results.
