 - May 1, 2010
These are general things I am curious about, and I figure there are a few people on here who might know the answers or have some insight for me. Some questions are super specific, regarding the various diamond and cbn stones that have recently become available, or regarding high vanadium steels.
- Why do manufacturers use CBN sometimes instead of diamond, and is there any benefit to sharpening with CBN over Diamond?
- If I want to put a low grit, like 600 grit finish on a high vanadium steel, do I have to use diamonds/CBN or is AlO/SiC ok?
- For low grit edges, what is a good way to deburr/refine a bit without losing that aggression? I am experimenting with a few stropping strokes on a spyderco UF stone, then a few on 1um diamond strop. It seems to work well on 154CM but I haven't tried it with my CPM-M4 folder yet, the one I actually need to be low grit for skinning.
- Are metallic bonded CBN stones more similar to a resin bonded stone like a venev, or a coated plate like DMT?
- Besides whittling a hair or slicing a sheet of paper, what are some tests you use to judge sharpness? For example, I fold and roll up a paper towel so I have a tight cylinder, then slice through it on a cutting board. Really tells me a lot more about how something will cut than the paper test or just feeling the edge with my fingers.
- Does anyone do a highly polished finish on high vanadium steels using diamonds, and then "expose the carbides" with a few strokes on an AlOx based abrasive, like an 8k waterstone or spyderco UF? I am experimenting with this and getting mixed results, I'm wondering if anyone has a particular technique or procedure they do that gets this effect. Trying to find that balance between maximizing performance and minimizing carbide tear out, and I'm not sure how much time I should spend on the ceramic, if I should strop a bit after... you know how it goes messing around with edge finishing.
That's probably enough super specific esoteric questions about sharpening. Hopefully the genuine experts and experienced amateurs who know the answers will see this. Thx
