Super ultralight compact titanium machetes for backpacking
Mecha
Titanium Bladesmith
Super ultralight compact titanium machetes for a long-distance backpacker.
These weigh only 7 ounces each! Lots of useful chopping power for something so light.
13.5" blade length, and about 21" oal, made of old VT23 titanium alloy. I call them a "kirichete" because their profile is sort of shaped like a gigantic kiridashi knife.
The thin leather sheaths are virtually weightless.
Hey Mecha these look neat - but aside from weight what are the pros and cons compared to a steel machete of same dimensions?
tradesies?😁
pro: ti is between steel and aluminum in terms of weight per unit.
pro: ti absorbs impact better than steel and has a longer fatigue life. I don't know if it's the generally lower hardness, or a property of the material. It feels like you lose less power to vibration or whatever, but I'm no scientist. There is a very solid feel to ti that is hard to explain, and for its weight it feels more powerful, all things being equal.
con: for applications where a very fine edge is required, ti just is really hard to get screaming sharp. It's so malleable, in a sense, that the burr is very difficult to remove. Polishing the edge is tough, in my experience, because I find I need to finish the burr off with a much lower grit abrasive and end up with a more toothy edge than you might want for cutting meat. It just can't get hard enough to compete at those extremely acute bevels required for certain kinds of knife. Unless its carbidized, but then you definitely don't get a polished edge.
pro: ti work hardens. I don't know how much, but it's noticeable. Say you have a burr still, just beat on it, eventually the burr breaks off. I've come back from trail sessions and found my Mechatichete is sharper than when I left.
A steel machete usually has a fairly obtuse primary bevel, at least the mass produced ones. As we know; geometry cuts! Sam's bevel work is extremely refined for an 'action blade' and it's not without some irony that his bevels have a very 'aerospace' shape to them. Much more acute edge geometry than factory machetes, and similar hardness, but with significant benefits. Significant benefits generally come with significant cost, but this blade with outlast many successive generations of any of us...
Agree. I kind of stopped talking about the shock-absorbing property and how it transfers more energy into the target. And how speed transfers more energy into a target than mass. How controllable a ti machete is, which makes it safer and able to be used more quickly and accurately, with way less fatigue. And how it's WAY more fun to use.
I'm going to rebuild my website soon, and it will have a lot of information about this kind of stuff.
Disagree. A hardened ti blade can get so sharp it's crazy, it just takes a different approach. But agree, although it's kind of easy to sharpen due to low abrasion resistance, it's maybe not the easiest to get screamin' sharp. It does get "hard' enough in that it's very resilient and stable for holding a fine, crisp edge.
Carbidizing is the opposite. It generally makes a toothy edge, rather than the extremely fine edge that's possible with a hardened ti knife with a fine grain. A carbidized one, if made right, is fantastic for cutting things like rope, leather, meat, fibrous stuff.
A hardened ti blade loses nearly all of its malleability, and with most alloys the edge will chip off rather than taking a set, but it takes a hard strike to chip it - not just pressure, due to its flexibility.
But yes the bur seems to drive people crazy. I usually sharpen them with the blade edge facing into a 2000 grit grinder belt, rather than dragging. But for knives I've had the best results with a 10,000 grit stone. I've tried a buffing compound with mixed results, and one of the sharpest edges I ever made was by cutting longitudinally with a super sharp Italian file.
Travis Wuertz sharpened the Ninja Sword from the Future at blade show, dragging the blade on the belts in the normal fashion. He damn near wore through his jeans swiping that thing trying to remove the bur. But when he was done it was one of the sharpest blades I've ever seen.
Often times to remove the bur I just slice through thick leather like 10 times. Works like a charm.
True. It's a fun phenomenon! Ti loves to get beaten. It's a sadomasochistic metal.
The resilience to shock damage is very high, hence why a thin machete can be made with bevels as acute as a kitchen knife and still cut hard green bamboo without edge-damage. I used to do the brass rod test with early machetes, haha. If that tells you anything.
Your machete is TiNb, my personal favorite alloy, which lurks somewhere between fully crispy "hardness" of some ti alloys, and the toughness of a typical, normal titanium alloy that can take a set and has a mushy edge. It's possible for it to take a set but not easy to do. It will also be really difficult to chip it off, short of hitting like a rock or chopping a fire hydrant something else like that.
These look killer. I want one.
Little anecdote from about 20 years ago.
A friend of mine unsheathed his machete from a thin leather sheath like this with his fingers over the sheath on the business side of the blade and the machete cut right through the sheath and severed all his tendons, right to the bones of his fingers. Luckily we were near a hospital but I’ll never forget that— when I unsheath a longer blade I always keep my fingers out of the cutting path of the blade in case it glides right through that sheath stitching. The long straight length doesn’t agree with any kind of sweeping motion. May want to consider a rivet.
Very cool! I have swung machete’s most of my life, and find them so useful. Hard to imagine one that weighs less than some of my folding knives. Pretty amazing.
Your stuff is always amazing. How do people order from you, if you are accepting orders?
Good points, and a lot of the older ones had a safety rivet. Nowadays they would probably get a few safety lanyard tubes.
These sheaths are only about 14" long, with a substantial welt, and slightly loose fit, so I think they'll be ok.
Thanks!
Usually by sending an e-mail or Instagram message, with a blade project request. Most of the time it's not possible for various reasons, but if the project sounds good, it will get added to my Schizo Wall diagram of stuff to do. There it sits, sometimes for years, until it somehow gets made or usually doesn't.
There are also some repeat customers who have this 6th sense for knowing when I'm getting broke and desperate, and just magically appear like a trickster genie from a lamp waving around a big down payment for some sort of project that's difficult to turn down. Then I beat my head on the wall finishing it with great effort and hate myself afterward, declaring in the mirror once again that I will not do that in the future. The cycle then repeats.
Then a message will come in from someone who had a totally reasonable request from like 3 years ago and I apologize for never getting around to it, and then proceed to never get around to it.
When something is finished and available it gets posted to Instagram first, where it usually gets snatched up before I have a chance to post to Bladeforums.
But I'm re-doing my website soon. It's going to be like an old-school site, where you can explore through it and find rabbit holes and nooks and crannies. I want to start putting some things on it that are available, particularly the fully-hilted swords and epic talismans.
R&D and experimenting with new processes and things are expensive and time-consuming, and those sorts of activities are always happening, which amounts to a price paid.
Ultimately, the process that made all of this possible is forging. Until I get a real-ass power hammer set up again, it will remain extremely difficult and inefficient. Then it will become regular difficult and inefficient.
It's a weird feeling....I'm still a learner.
The only thing I can contribute in a meaningful way is Speed.
Idk yet if it's a Pro or a Con? It's hard to describe, but you need to swing Faster.
It looks like a beautiful day outside, I should go an swing it some....
Gotta give it the ol' flick of the wrist.
Here is a review of a titanium machete from someone with super extensive use of machetes:
