"Superfast" knife project - free parts
We have a material we call Lubricium. It is a cold reduced stainless steel. It has a much lower friction coefficient in many applications. We think it should make folders that open faster. It should allow knife artists to make knives with tighter tolerances, which should mean stronger knives.
This is how we think it should work. There are two considerations. 1. Not everything works in real life the way it works in the lab. 2. This is real top end performance stuff and I am not sure how many knife users will be able to appreciate the difference.
What I would like to do is supply some parts to knifemakers and get their opinion and the opinion of sophisticated knife users. I'll pay for enough parts until we get a clear picture. This is new and it will take a while to get it worked out but I will send a part or material if you want to experiment.
If you would, could we do this through Chuck Bybee at Alpha Knife Supply? Rob and I still love you but Rob wants to make knives and I want to do research so we are working with Chuck Bybee, The Titanium Man, to sell Talonite® and other alloys. http://www.alphaknifesupply.com
For more info on the alloys see www.carbideprocessors.com
Tom Walz
From what I understand, folders are the only place it will make a difference. Its meant to be used for hardware like pivot pins, where movement calls for reduced friction, without compromising strength and precision.
Lubricium is our Impervium that has been cold reduced. That means they hammer it for a couple days to reduce it by about 40%. This does sensational things for the grain structure. You may use it anywhere but it is much more expensive than the Impervium so we recommend it for moving parts. Both are totally non- galling stainless steels. As with Talonite these have a long military / industrial history. In this case they are used widely on minesweepers, for example, so it is non magnetic and corrosion resistant.
See www.carbideprocessors for more info. Contact Chuck Bybee at Alpha Knife Supply if you want to get in the free - part for testing program.
Thanks,
Tom
