- Dec 20, 2001
I'm fortunate enough to own both the L4 and an A2. Reason being, the L4 was released about 1 month after the A2 and I just had to have it. They make for an interesting test comparison head to head.
The L4 runs at 65 lumens for about the same amount of time 60-65 minutes as the A2 runs on its 65 lumen xenon bulb. Both are about the same "brightness" visually. 62-65 lumens, is 62-65 lumens, whether from an LED or a xenon, and both will just about blind you. The L4 has it all over the A2 for "whiteness". You turn night into high noon with that sucker! Now the L4 will provide about about another hour of "moderate" light after the first hour of high output, and up to 15 hours of "useful light" according to the package insert. That "useful light" is about a little more than a photon III IMHO, and ain't too freaking "useful" in a light this size. The "moderate" output second hour is about equal to the A2's LED output. But you only get an hour of that, before it becomes an oversized photon III. The advantage the L4 has is that there is no pricey, difficult-to-get, xenon bulb to replace EVER! You lose alot of versitility when you go to the L4 over the A2 because you don't have that long run, moderate output, LED option. And if for some bizzare reason the LED module in the L4 fails, you're pretty much SOL. Something to think about where it would be nice to have options and a built in "back-up." I use the A2's LED output much more than the xenon anyway so I tend to carry that one more. And to make matters more complex, ARC is coming out with a new light this Fall that may render the LSH "relitatively" obsolete! One other plus for the L4 is it has a tailcap "click switch" for constant "on" as opposed to rotating the tailcap on the A2.
