John,
First, congrats on the surface grinder.
When grinding thin sections on a magnetic chuck, some electric chucks have a control on them which allows you to adjust the strength of magnetic pull, without that feature, I use shims to build-up under the parts to keep them straight when the chuck is turned on. I have shim packs with shims from .001" to .035" in .001" increaments. You'll have to hold the parts flat on the chuck how you want it with one hand and try fitting shims with the other till you get it shimmed out, if you are grinding the tang you may also have to shim the tip end to keep it from bending when the chuck is on.
Two things are going to happen when you do this, you are going to loose grip and cooling. Even though the shims are steel they will not transfer the magnetic field thru them 100%, the fix for this is to get some bar stock slightly thinner than what you are grinding and block the sides and the end the grinder is trying to throw the piece off the chuck ( three sides ). This technique is not for those with a weak bladder, the surface grinder can be more dangerous than a buffer when it comes to throwing pointed objects and I haven't seen too many buffing wheels explode while doing so. The magnetic chuck acts as a hugh heat sink, when you insert the shims between the chuck and the blade you loose that cooling effect, you will need to use coolant or flip often as Don mentioned above.
All the above is only for grinding with the blade long-ways on the chuck and assumes you can judge how much you can take per pass safely depending on your set-up, if you want to turn the blade sideways and grind a step at the guard shoulder, you will need to make a fixture to clamp the blade to which supports the tang and is held on the grinder by the magnetic chuck.
Steve Seib
