Surgery Went Well
Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
As some know, I had a rough last six weeks. I got very ill, then developed severe joint pain, lost 10 pounds ( not everything is bad, I guess), and was getting ready for shoulder surgery on Nov 16th.
I got well enough to pass the pre-surgery physical, even though I was pretty stiff and sore and had started walking badly on my right leg which has been a bone on bone knee for years. That is due to be replaced in this winter. They took me off my anti-inflammatory meds eight days prior to surgery. The first couple days were bearable, but not comfortable, then on day three, I had a re-bound reaction and my knee went crazy. By Tuesday, it made my foot turn out sideways and that caused my ankle to inflame. The Achilles tendon developed tendinitis, the bone from knee to ankle hurt worse than if it was broken, the ankle swollen to double size, I couldn't put my foot down without excruciating pain, and could barely hobble around with a cane ( remember, I am the guy who sews himself up when I get a cut, so pain isn't normally a problem with me). It got so bad by Wednesday, I took a Percoset, went back on my Celebrex, called the doctor and told him to cancel the surgery, and get me in his office ASAP.
They saw me the Thursday AM. After a lot of X-rays of the knees and ankles, it was confirmed that there was no new problem with the knee, an the ankle was normal, just extremely inflamed. The knee was injected, and within ten minutes it was better. The doc said he wasn't canceling the surgery, and to stay on my meds. By that evening, my ankle was 3/4 back to normal, my gait was much better, and I stopped using the cane. By Friday morning, 6AM, I was walking straight and fine. I walked into the surgery without leg pain at 7:30AM.
The arthroscopic surgery was for a SLAP tear, debridement of a few small osteophytes (AKA -spurs), and a close inspection to assure no rotator cuff repair was needed. The rotator cuff is fine, and the only new info discovered was they found evidence of an old impact fracture, which could have happened any time over my arm's 60+ rough use years.
I woke up feeling great. They had put a new take-home chiller pack machine on my shoulder. It pumps ice water through supply and return tubes from a small cooler (looks like it would hold 4 beers), which has a self contained pump, to a cold pack that will fit any leg or arm joint. It cools the joint deeply at 45-55° and does not need to be removed every 20 minutes to prevent skin damage like ice does. The deep cooling is far better than the skin near-freezing of ice. It runs 6 hours on a fill of ice and water. The supply tubes clip into a feed tube from the chiller pack for easy connect/disconnect. The great thing is I can use it on my knee when it acts up occasionally. They will give me a new one when the knee gets replaced, and this one is the exact thing to supply Nathan's chiller platen with continuous cold water all day long. A real win-win!
Feeling great today, pitched the sling already, only took two of the pain pills yesterday and am staying off them today, as I feel almost no shoulder pain now. I will take it easy for the rest of the weekend.....well, at least fairly easy.
Good to hear everything went well and you are feeling good! Heal fast and get some rest.
I'm a bit surprised you didn't do the surgery yourself but I guess everyone needs a hand sometimes. :D
Get better soon!
Modifying medical equipment for knifemaking purposes; classic!
Don't rush it. Do the PT when it's time, and don't overdo.
I've had knee, shoulder, and both hand surgeries, did the PT
as prescribed, and things are back to normal.
Just goes to prove we ain't getting any younger. And the younger
folks should learn from our self-inflicted damage TO NOT DO IT.
Good luck and fast recovery.
Bill
While waiting in the OR for the doc (he was running a bit late), the nurses and I were discussing some medical things and I was using medical terminology. Somewhere in the conversation I must have mentioned suturing myself when I get a cut. It went silent, and one asked if I was a doctor. I told them "No, but I have a bit of medical background." The conversation turned to what I do and how I suture myself. I was explaining the reason one could push a needle in his own skin with far less pain than when another does it, due to my ability of letting my brain tell my nerves that this is OK, and thus turning off the pain sensors. ( I tried that hard during the pain the other day, and my leg overrode the signal, saying it was NOT OK). When the surgeon arrived, he asked what was going on, and one of the scrubs told him that I sutured and did minor surgery on myself if I needed it. Dr. Gibson laughed and said, " I had to talk him out of doing this surgery himself. Let me in there before he changes his mind :)"
Bill
Thanks, Bill.
My favorite line is, "Getting old ain't for wimps!"
The doc knows me pretty well, and knows that I will not do more than I should. He told me to move the arm through the full range of motion starting today, and use it pretty much as it directs me. As he said, "It will let you know when it doesn't like something."
I know normal post-surgical pain from damaging pain, and without pain meds the difference is clear. Because there are no repairs to damage, as would be in a rotator cuff repair, I actually need to keep it moving ( within reason) to avoid adhesions. I won't be swinging a hammer for a week or two, but I may grind a blade tomorrow if I feel like it.
I had a feeling. :)
My Dad was a medic in Vietnam and is the same way. I wish I was that tough!
Good to hear you got the dents popped back out, Stacy!
Smoke and prayer for good and gentle healing, well as much of it as you'll allow anyways.....:p
Be careful and good to yourself and listen to the doc.... he's the one with the degree. ;)
Good to hear you are doing well.
I had the same sort of cooling unit for my first elbow surgery, but it was a rental so I had to give it back.
Just saw my new surgeon on Tuesday and going back in for surgery in 6-14 months. Would have had it done last year if I hadn't had to move so suddenly.
Heal up Stacy and resist the urge to do too much and you will be back up to speed in short time. One has to be patient with worn machinery as we age and fall apart. As long as it starts and runs thats the main thing.
So you'll soon be ship shape and Bristol fashion. Good to hear you're on the mend even if the thought of you doing your own suturing makes my arm hurt. Get completely well soon.
My mom used on of those machines for a while after she had major foot surgery. She said it really helped.
