- Mar 2, 2010
I finally was able to get myself one of the HI Survival knives from this DotD. It came today along with one of the Kami Heath Fund Sheaths. I will first say that I am really surprised at this knife. It is really beefy and feels like it can take on any task that will be asked of it. Mine was made by Kami Bhatkta, the "Bow & Arrow" Kami.
It came to me nice and sharp too. :thumbup: Of course I can't help myself and will take the edge to the next level even though this is a perfectly serviceable edge.
I am sure that you all want those specification so without further ado:
OAL: 12 1/2 Inches
Blade: 7 1/16 inches
Inner Diameter: 1 1/8 inches
Outer Diameter: 1 2/3 inches
Blade Thickness: 1/4 inch
Weight: gonna guess it is close to a pound
The regular spread of pix first...
Now let's do the comparison between the Himalayan Imports Survival Knife and Cold Steel's Bushman and for kicks I put my Mini Bushman int the mix as well.
Right off the bat you can see the HI SK has a much nicer sheath on it, even with a snap that needs moving. The Sarki simply does a better job on this that the assembly line machinery. Also note my Bushmen as old. They don't even come with a leather sheath anymore, rather a nylon one with plastic reinforcements. To speed production, the Cold Steel line uses some kind of rivet/staple hybrid instead of stitching the sheath together.
The blade shapes are also different. The HI SK has not belly while the CS blades have a nice one on them. This is about the only thing I would change as I like a blade with a bit of belly on it. Makes it more handy in the field IMO.
The spine shot tells the tale though, HI makes a blade that will hold up to nearly anything you ask of it while the CS blade is a cold rolled piece of thin steel stamped out of a sheet by a die. Of course this does make them cheaper, but not all that much really when you look at the new catalog.
All of them have a socket handle which lends itself to making am expedient spear out of the blade. I haven't done so yet with the HI version but I would wager with the increased weight, it will make a hard to throw spear due to imbalance. I have thrown the CS Bushman Spear, all three types (Bowie Blade, Regular and Mini) and while the bowie blade makes for a poor throwing spear, the other two make great spears and can be hurled accurately easily and with enough force to take small game like porcupine or geese or rabbits etc. I will have to try out the HI Survival Knife to know for sure. I can say that the HI version lacks the easy little hole for attaching the knife to the spear but with all the cord it comes with, this is easily taken care of by lashing it there instead. There also seems to be some folks who thing that the CS socket is somehow different, that it isn't open on both ends like the HI one. I hope this picture ends this confusion...
The only thing I would like to see added to the HI line is a smaller version like the Mini Bushman that Cold Steel made some time ago (now discontinued). I bought three of those little buggers and find myself taking them along camping (when I did) far more often that I ever did any of the big Bushmen (Regular or Bowie). Sometimes a small, multipurpose blade is better than a big, honking machete IMO. Would have done things like batoning and other testing but those have been done already so I went ahead and did a more in depth comparison between the HI Blade and its inspiration. Hope it helps out and I hope some of you grab these up as I think they would be fantastic knives for all around field use.
OAL: 12 1/2 Inches
the retention strap's snap is too snug to close...
I have some things to try to fix it before I put a new one on though
Killa's all important "Spine Shot"...
my favorite, the "In Hand" shot...
