I have survived in the desert under extremely harsh conditions. During this time, I have used all solar methods of aquiring water. Although the underground solar still will produce water... I don't believe it is not worth the amount lost in its creation. However, if created at night, the impact will be far less...
Question: Can you live on the water from a solar still?
--An underground solar still is NOT highly advisable in a true survival episode. They require you to expend energy too create and will yield only small amounts of water in return. In addition, to be effective they have to be moved every two days. If you do decide to use one, you can increase your results by lining the sides with non-poisonous vegetation, salt water, or even urine. The added condensation that drips into your awaiting container is sterile and safe to drink. A better option would be:
--Vegetation bag: this requires filling a bag with non-poisonous vegetation and placing it out into the direct sunlight. By creating a low spot for the subsequent condensation to pool you achieve a water source. Drink off the water at sunset so the vegetation doesn't reabsorb it. The vegetation will need to be changed about once every two days. Better yet,
--Transpiration bag: Using a shrub, tree or bush... cover sun exposed, non-poisonous vegetation with a clear plastic bag. Create a low spot for the condensation to pool. Drink off the water at sunset. Move it every two days. Best part of this system is that the area previously used will rejuvenate and be reusable in several days.
With all of this said... I must admit that it is presented in my first book as an option for water procurement... it is an option just not a good one... it does produce water (I can usually get one to two canteen cups full a day) ... once again, the impact of water lost during its construction can be minimized by making it at night (it doesn't require much energy to create).
There are no clear cut answers in survival and all options should be presented... IMHO.
Greg Davenport
Simply Survival's Wilderness Survival Forum
Simply Survival's Web Page
Are You Ready For The Challenge?
Are You Ready To Learn The Art Of Wilderness Survival?
