how you got there lets say you where hiking in the area and main pack was taken at night by the locale wild life.
apart from your main pack down u have whatever s on your belt and in your pockets
cheers forrie
The difficulty in places like this is that you can be many, many miles from any source of water. Temperatures can be extreme and exposure to the sun for any significant length of time without drinking water is likely to be fatal. Thus you shouldn't just wander around hoping to come across a water source - if you're sure of one and it isn't too far then fine, but otherwise stay put.
The best advice in a place like this is to find/build a shelter which provides good shade, and to stay under it for the entire daylight hours. Lying still will prevent fluid loss through sweating. If you had a plastic bag, you could collect some water from the shrubbery, and if not you could probably still get some moisture out of the leaves. Forget about eating as the digestive process uses up water.
Temperatures drop significantly at night so this is the time to be doing any activity if it is really necessary. Just watch out for the snakes that are out and about at this time, and don't fall over and injure yourself in the dark. I'd prepare a fire which I'd keep slowly burning with plenty of green vegetation next to it, to be used as a signal.
Other than that, sit tight and wait for rescue. You did tell someone where you're going and when you're due there, right?
Well I assume you knew where you were before you went to sleep and lost your pack.
Even though I live 2,000 miles from this place and I've only been to it, once in my life, 12 years ago, I recognise it, as many Australian should, as being somewhere in the Kimberley Mountain Range. So I guess the next step depends if it was the wet or dry season and where you left your vehicle.
Ok guys and gals lets say you only have one fixed-blade under 6 , no hatchet and main pack is lost.
Need I say more about location
Lets cover all points cheers guys
Ill leave the rest up to you cheers forrie
