I prefer the aggressive texture of the old style G-10 on my Hold Out III so I tried swapping blades with my XHP version this morning. Worked perfectly! Only the blades were swapped as they have changed the pivot pin location on the lock bar and the pins are different due to the slightly thinner G-10 on the new version. The swap works both ways so you end up with two perfectly working knives. No cannibalization of parts. Because of this, make sure you check the etchings on the blade for the CTS XHP marking if you are buying a 2015 model second hand or from an unfamiliar source.
